Additional reverse lights
Old Apr 9, 2012 | 11:51 AM
CraigSnedeker's Avatar
Default Additional reverse lights
I want to mount two lights to my roof and connect them to my reverse lights, how do I go about doing that?
Thanks
Old Apr 9, 2012 | 12:01 PM
Old Skool Soldier's Avatar
Old Skool Soldier is on a distinguished road
Could always ground the lights out anywhere, then run the wires down the back hatch, and tap into your exsisting reverse light wiring. Doing that would cause them to come on every time you threw 'er in reverse though, alternativly, you can run a completlely independent wiring system, up to a toggle switch in the dash that would give you control over when the lights come on
-OSS
Old Apr 9, 2012 | 12:05 PM
Rottidog's Avatar
Mount them & have a relay activate a high current line that feeds the lights. The stock power to the reverse lights won't be enough to run aux. lights like a pair of 55 watt halogens or whatever you're using. Tap into the existing reverse lights wiring to activate the relay.
I'd put the ground for the relay on a switch that you mount in the cab so you have the choice of when they're on.
Old Apr 9, 2012 | 12:35 PM
Alright, thanks!
Sounds pretty advanced to me, haha. But I'll get it done!
Old Apr 9, 2012 | 06:43 PM
Rottidog's Avatar
My pleasure... get a self stripping tap from an automotive place, the type where you run the wire you want to tap into through it & run the end of the wire that you're going to use, in it. Crimp the U shaped plate down & close it.
Google Image Result for http://www.galesburgelectric.com/files/images/large/d_7645.jpg
That's all the current you'll need to activate the relay.
Old Apr 10, 2012 | 01:50 AM
Thogert's Avatar
Yeah a relay is the way to go. That's how I did mine.
MetalMan390
Apr 1, 2011 12:24 PM
Steinbruchsoldat
Sep 24, 2010 02:16 PM
jug
Nov 7, 2009 12:04 AM
DriftinBlzr
Oct 4, 2009 07:32 AM
