Of course the common fuel gauge
Old Feb 21, 2022 | 10:46 PM
bfathman6's Avatar
bfathman6 is on a distinguished road
Ok I will do this tomorrow, until I can reply again. I noticed with this connector above the brakebooster. When connected, Fuel reads way past F when in RUN. When disconnected, the gauge goes to 3/4 in RUN, then when off takes a few seconds then bounces to F. This blazer has sat for some years and if you look at wires that go into driverside firewall im wonder if maybe in that mess the coating might of became brittle if there might be a issue there as well. Thank you for your time.
Old Feb 21, 2022 | 10:48 PM
bfathman6's Avatar
Old Feb 22, 2022 | 03:49 PM
bfathman6's Avatar
Default Readings
Originally Posted by bfathman6
I tested as requested the load by back probe. Colors You gave were different however on A 5,7 V , B 5.7 v , C 11.57 v. I appreciate your time with this forreal
Old Feb 22, 2022 | 05:15 PM
GeorgeLG's Avatar
What you have in your hand is the door lock relay module. If that's what you tested then we need to find the fuel level buffer module under the glove box. It has a 13 position connector all in one row with 6 wires and 7 no connects in the middle. 4 wires on one end, 2 wires on the other end.
George
Old Feb 27, 2022 | 02:07 AM
bfathman6's Avatar
I apolgize for the late reply, I will look under the glove box panel for it. thank you.
Kevinrs
Mar 17, 2013 09:26 PM
abukinan
Apr 19, 2011 03:46 PM
unklemike00
Oct 4, 2010 06:44 AM
cejay825
Sep 29, 2008 04:28 PM
sobtom
Aug 11, 2008 07:56 AM
