gas gauge doesnt work
Old Apr 26, 2014 | 09:13 PM
hoebob69's Avatar
hoebob69 is on a distinguished road
Default gas gauge doesnt work
My gas gauge is stuck on full. It sat for over a year while I was working on it and I recently had to change the fuel pump because it wasn't sending enough pressure. I'm assuming its either the float,sending unit or the wires. Is there any tests I can do to better diagnose the problem?
Old Apr 29, 2014 | 01:02 PM
abig84's Avatar
check your grounds. is it way past full? that usually indicates a ground problem.
Old Apr 29, 2014 | 07:12 PM
hoebob69's Avatar
Mine is digital so it's a bar thing. But that sounds like a winner.
Old May 1, 2014 | 12:52 PM
abig84's Avatar
yeah not familiar with the digital gauge. but having owned a bunch of 80s s10s and k5 blazers over full was always the ground, if the gauge was just stuck and not moving it was the pink wire running inside the frame rail somewhere
Old May 1, 2014 | 08:40 PM
hoebob69's Avatar
Yea I know the harness on these are known to go bad and I thought there was a way to check those with out dropping the tank
Old May 2, 2014 | 12:45 PM
abig84's Avatar
the old fullsized trucks used to just corrode in the frame rail, you could just look at the wire and see it was all green and nasty. the grounds i believe are their own wire, like they bolt to the top of the tank and go to the body or frame. to test the sending unit you have to do a ohm test on it but i forget the exact details on how to do it, its been like 12 years since ive done one
davidcrowder
Nov 9, 2019 02:39 PM
justin12234
Feb 15, 2012 02:56 AM
americancarguy.com
Sep 6, 2010 09:55 AM
stevenf
May 24, 2008 07:49 PM
idg4ever
Jan 22, 2007 07:41 PM
