high pitch noise?
Ok. I honestly don't know what section this should be in. I'm not very knowledgeable about vehicles yet, because my blazer is my first. I'm guessing it's an elevtrical problem, but I have no idea. My blazer makes a high pitch noise, which sounds like it's coming from the dash. The noise gets higher as I push the gas pedal closer to the floor. Does anyone have any idea what that could be? It also gets louder wjen I turn the radio on, which is why I think it's electrical.
That sounds like engine while through your speakers.
Sounds like a ground loop (even if you have a good ground to your stereo, Try pulling the radio, and grounding it to a different location, to give it a better ground) should solve the problem.
tip can be used for both your current and after market
Thank you for the tip. I know a little about wiring cause I did roofing/siding/ pretty much any house construction 2 summers ago for a summer job while out of school, and I wired lights up. But I've only wired speakers into my car so they're different. Would I need a new wire or could I unscrew the old ground from the dash and just screw it somewhere else?
I honestly would splice into the wire as close to the radio as possible and run a new wire, you can either splice into it so that you keep your other ground, as well as have a new one. could help even more.
kelly2
May 8, 2015 09:10 PM
GloryImSaved
Jul 14, 2009 06:26 PM
chevyblazer2008
Jan 8, 2008 05:44 PM
