Obd 1.5 paperclip trick?
Old Aug 22, 2017 | 04:43 AM
  #21
Tynan Tha Real Dill's Avatar
Tynan Tha Real Dill is on a distinguished road
Originally Posted by Rusty Nuts
The orange wire in pin 16 is usually the power feed that's 12 v. at all times. Now we know for sure. Sorry to hear that autozone sold you another defective battery. Good thing it's under warranty.
Damn... No I don't have a warranty on it, bought ot from a salvage yard. How much do u know about the inside of a CPI Spider injector ?
Old Aug 22, 2017 | 04:48 AM
  #22
The darker one is from my spider, is it dirty and clogged? And what is this piece?
Old Sep 1, 2017 | 08:14 AM
  #23
LesMyer's Avatar
Maybe this will help. Reading codes from OBD 1.5 system
Old Jan 16, 2021 | 02:37 PM
  #24
Auto Restoration Guy's Avatar
Auto Restoration Guy is on a distinguished road
my connector does NOT have a pin in slot 4.
my Innova 3020b scanner won’t read the codes it says error, so I assume it’s OBD 1.5, ....
without a pin in slot 4, and no keyed power to slot 2, how do I read the codes?
10/94 build date, computer under hood on passenger fender, obd2 connector under left side of dash.
help??
Old Jan 16, 2021 | 08:54 PM
  #25
GeorgeLG's Avatar
Pin 5 is a gnd along with pin 4 so you can use pin 5 instead. Pin 2 is a data line, not power.
George
Old Jul 12, 2021 | 09:01 PM
  #26
Cresfonte's Avatar
Cresfonte is on a distinguished road
Place the jumper wire in pin 2 and 4
Hello Rusty, I have the same issue. Doing this won't cause any circuit on the computer or something? I have a 93 S10 and i scan it with a jumper wire in pin 4 and 6, but this other Chevy I've got doesn't have a 6th pin. Only 2-4-5-9-13 and 16.
Old Jul 26, 2021 | 01:48 PM
  #27
Martymar's Avatar
Martymar is on a distinguished road
That is the "maxi" injector which opens and closes fuel to pressurize fuel to your injectors. It's like one big injector that feeds the rest. Wiring harness sits on top and is related to ignition timing. Mine is stuck open and forced to get a whole assembly
Gnfanatic
24
Jul 22, 2022 12:33 PM
klote82
16
Oct 10, 2018 06:22 PM
David Wolstenholm
May 20, 2017 08:54 PM
Denominator
13
Oct 3, 2012 08:59 PM
rastaskater
Mar 12, 2008 06:22 PM
