Power Mirrors Not Working.
Old 01-24-2011 | 08:25 PM
vcampsteam's Avatar
vcampsteam is on a distinguished road
Default Power Mirrors Not Working.
I just got a 1998 2 Door Chevy Blazer From my uncle, and right after I went out for the first time with it, I found that the power windows aren't working. I was wondering if anyone knew what/where I could check to fix it. Sorry if this is the wrong area, I'm new to the forum and this is my first post.
Old 01-24-2011 | 08:58 PM
warthogdriver's Avatar
try fuses?
switch itself might be bad.
loose wire behind door panel.
i was able to pick up a new switch set for driver door from junk yard for cheap.
easy to swap out.
just a suggestion. try fuse or loose wire first.
i am thinking if both mirrors are out, maybe switch went bad.
Old 01-24-2011 | 11:30 PM
ABN31B's Avatar
common issue. a lot of moisture gets down in those switches on the d side door.
Pull the switches, take them apart, and clean all the contacts with rubbing alcohol and/or a pencil eraser. Re-assemble and give it a go. you can also try diagonal angles. sometime you can "force it".
RoxStar33
11-26-2012 08:46 AM
Jumpman227
09-29-2012 11:02 PM
kickme005
07-10-2010 11:07 AM
shibbershabber
02-21-2010 01:43 AM
fresno99
07-31-2009 09:12 PM
