Quad beam on 98+
Old Mar 6, 2010 | 04:14 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
yea i know, i just thought it was funny that he said they wernt and that the wires wernt the same color, when they use the same wiring harness.
Old Mar 6, 2010 | 09:41 PM
elementtrev's Avatar
elementtrev is on a distinguished road
what i had to do was splice into the drivers side headlight, the yellow wire WITHOUT the black stripe and ground it to the core support with a self tappin screw. mine is a 2001 BlaZeR 2
Old Nov 29, 2011 | 07:08 PM
87yellowsuzi's Avatar
87yellowsuzi is on a distinguished road
So did you do only the driver side? I have A 99 blazer 4x4, and I'm having the same problems. Driver Side works fine. Passenger side is dim on low and when switched to high beam, my passenger side goes out all together
Old Nov 29, 2011 | 07:40 PM
TMM217's Avatar
TMM217 is on a distinguished road
I made it simple on my 04. I used a paper clip to tap into the yellow wire at the socket then used a wire with alligator clips on both ends. One end to the paper clip and the other to a good ground, I used a self tapper sheet metal screw to radiator support for my good ground. Its like a 5 minute project. Only did my driver side no need to do both sides.
Old Nov 30, 2011 | 12:09 PM
Well, I still had no luck. So what I did was, went to the junk yard and got a couple pigtails, tapped into my driver side and ran new wires to the passenger side. And tucked away passenger factory harness. Left the yellow wire grounded on passenger side. Seems to work ok.
cr8390
107
Jul 17, 2018 10:58 PM
NorthernCrew454
Jan 26, 2010 11:42 AM
blazedandconfused95
Oct 22, 2009 12:26 PM
NVANZEE
Dec 22, 2008 06:18 AM
portcqb
Oct 9, 2008 06:35 PM
