turning off the accessories outlet
Is there a way to turn off the accessories outlets on a 98 Blazer, when you turn off the ignition ? I hooked up a xm radio it gets power from the acc outlet if I forget to unplug it will drain my battery.
Personally I'd just wire in a new acc powered outlet. Or, even, just cut the wires to one of the stock outlets, and grab power from an acc powered circuit and wire it up. Of course it is always a good idea to use a relay and fuse just in case, but I know the risks.
Staticxtreme5
03-31-2011 07:43 PM
jeffintoronto
12-16-2009 11:54 AM
