85 Blazer K5 Power steering fluid leaks out of the top
Old 08-26-2012 | 10:03 AM
Agentsnake's Avatar
Agentsnake is on a distinguished road
Default 85 Blazer K5 Power steering fluid leaks out of the top
Hello Folks,
I know this is not the right section to open this thread but I am a new memeber and can't post it anywhere else.
Short description of my problem :
Power steering fluid leaks out of the top of reservoir
- I did check the fluid level and did make sure it is way on the
lower side
- I did replace the cap just in case
- I did check the low pressure ans high pressure line they are fine
- I do have little wine noise but not so bad
- When I drive steering goes easy if I stop it goes easy in the first moment than steering becomes weak if I rise the rpm in neutral a little steering works better .....
I feel sure the pump is just old and need to be replaced what you guys think ?
thanks for any tip
regards
Gunter
jake kick
04-27-2013 02:25 PM
rocknroadie
01-22-2013 07:05 PM
tomf216
01-28-2010 08:37 PM
90blazinchevy
10-05-2007 02:52 PM
gmaltese
09-15-2006 02:18 AM
