Death Wobble?
okay, so my friend tells me he has a problem with a jeep cherokee laredo
says if he hits a small bump "it will shake like crazy" and goes away when he slows down, so.........What will cause this problem? sounds like the death wobble to me
- pettyfog, elaborative asst to Kyle.
You can have perfectly balanced tires exhibit this phenomenon. The tires are often not the cause of the issue, it is the slop that is already present and/or the inherent design of the steering (think K5 Blazer). Larger tires do have more mass, but that isn't the only factor. The larger the tire on the same size rim, the more flex there is in the sidewall which can exacerbate the issue, magnifying the slop.
I would go through all of the joints in the steering and replace anything that feels loose or sloppy. Also, if the truck doesn't have a steering damper (shock), I would recommend one be installed.
Had that problem on my 94' Ram 4x4, it was the track bar.
The track bar keeps your front axle aligned perpendicular to the frame.
Not sure if the Jeep uses the same front suspension.
If it wobles that bad it should be very apparent what the problem is after the truck is jacked up and the steering is run from hard left to hard right.
chris015
Dec 5, 2010 10:35 AM
