help brake repairs
Old May 4, 2011 | 09:32 PM
coach jj's Avatar
coach jj is on a distinguished road
Default help brake repairs
Any idea on ball park price for front and back pads and rotors?
Had mine replaced today now I have smoke coming from the rear wheels.
Told I need new calipers. price?
Old May 4, 2011 | 10:51 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Search it on Autozone.com. Even if you don't go there to pick them up, it'll give you an idea. Enter your vehicle information and it'll bring up everything you need.
Old May 5, 2011 | 04:53 PM
AuSSenseiter's Avatar
AuSSenseiter is on a distinguished road
I am going to stick my neck out here and say that a bit of smoke is actually normal. If you've replaced both the pads & rotors, then likely the smoke is actually the machining oil burning off the rotors. Depending on the amount of oil they coated the rotor with, the smoke can range from not even noticeable to WTF? Is my car on fire?!!
My suggestion would to be go ahead and drive your truck. The smoke should disappear shortly but after 500 miles, go ahead and check the rotors & pads. The parts should be under warranty so if you do need calipers, you can replace everything all at once and have a whole new system.
Selwen
Apr 5, 2010 07:58 PM
BonestockZR2
Nov 2, 2009 07:00 PM
dacop
May 14, 2009 02:25 PM
wienerdog
Dec 2, 2008 05:56 PM
returnofsid
13
Jun 3, 2008 01:21 PM
