Lowering Tech This section is for suspension questions related to decreasing the ride height of your vehicle.
4x4 Frame Swap to 2X4
Old Oct 10, 2008 | 10:40 AM
dubb_05's Avatar
dubb_05 is an unknown quantity at this point
Default 4x4 Frame Swap to 2X4
I was wondering if a frame from any s10's or a 4dr would be the same.. I have a 2dr 4x4 blazer and want to swap frames to a 2x4 frame. Can I use a s10 frame or a 4dr frame? Or does it have to be a 2dr 2x4 frame?
Old Oct 10, 2008 | 10:49 AM
Default RE: 4x4 Frame Swap to 2X4
You would definitely have to use a 2dr frame and it has to be from a non-ZR2 (yes they were offered in 2wd as well in the later years [&o]).
That is a whole lot of cost just to switch your truck from 4wd to 2wd...
Old Oct 10, 2008 | 12:55 PM
packofqtips's Avatar
packofqtips is an unknown quantity at this point
you could take a 2wd pickup frame and use the front clip and have that grafted onto your blazer frame otherwise you will need a 2wd blazer frame
Old Oct 10, 2008 | 07:09 PM
95_4door's Avatar
95_4door is an unknown quantity at this point
What about just taking the 4wd components out and swapping in a 2wd trans and driveshaft?
It would be cheaper and easier in the long run.
Old Oct 10, 2008 | 09:17 PM
the suspensions are very different and if you remove the front half shafts the hubs come apart
Old Oct 11, 2008 | 05:16 PM
95_4door's Avatar
If you leave the outboard stub, you will be fine
mcatnova
Feb 16, 2012 10:36 PM
MrDave14
May 4, 2011 09:40 PM
Terry Bonnar
Suspension Tech
Apr 15, 2011 03:08 PM
rebelchevy
Jul 31, 2008 10:58 PM
dubb_05
Suspension Tech
Apr 5, 2008 12:41 AM
