Great Upgrade for cheap!
Old Sep 12, 2007 | 11:37 PM
  #21
drperry's Avatar
Default RE: Great Upgrade for cheap!
ORIGINAL: lennyblazer
According to that data, you can tow a little more than an automatic with the manual. If you have a 2wd xtreme Blazer, their tow rating is 2000 lbs.
Trailer towing maximum (lb / kg):
2WD*: 5700 / 2585
4WD: 5400 / 2449
* 2-dr / 2WD Xtreme = 2,000 lb. (900 kg)
Actually, that only lists the difference between 4x4 and 2WD... But in my owners manual, it lists the 2 door, 4x4 5-speed at 3,900lbs towing capacity, and the auto version is rated at 4,900...
Edit: sorry for the double post... lenny must've posted while I was replying to Hanr... and apparently I can't delete my post, so.... yeah, lol.
Old Sep 13, 2007 | 03:47 PM
  #22
99 Blazer 4x4's Avatar
99 Blazer 4x4 is an unknown quantity at this point
Shackle for the rear like the ones that can be slid into the reciever. I had a different setup which has just come off in anticipationof the lift kit and other goodies yet to be install. It had the usual reciever type hitch with a farmers clamp (you could call it something different but thats what I know it by), which you can find at a Tractor Supply or a rural farm type store. It is kind of like a giant clamp with a locking pin that also has a guard so that if you start to move side to side or for that matter start to accidently start to pull unstraight the tow strap or chaing will not damage your truck. The reason I installed this type of hitch was because sometimes I have to empty the back off my blazer so I can haul and I don't always have time to put my off road gear back in. This way if one of my friends call or I come upon somebody stranded with a tow strap all I have to do is lift the top portion drop the strap onto it and drop the top part down slide the pin in and pull them out. Just my opinion, everybody has there own setup that they like and what works best for them.
Old Sep 13, 2007 | 05:29 PM
  #23
drperry's Avatar
Pintle hitches are expensive, lol.
I want some of those reciever tubes, so I can get me a fancy 2" reciever setup, kind of like a rear hich, that's removable.... But still connects to both frame rails...
And I'm waiting on the Synergy Offroad hidden winch mount to make its way to ebay... lol.
Blazers.B.Kewl
Sep 8, 2009 04:22 PM
BADFNC5
Dec 19, 2006 04:33 AM
XBlazer01
Aug 29, 2006 10:12 AM
arbowman
Aug 25, 2005 07:41 PM
2001Blazer4x4
Engine & Internal
Aug 1, 2005 01:23 PM
