Looking to Lift - Can I increase my tire size?!?
Old Feb 3, 2007 | 02:06 AM
  #21
Goat's Avatar
Goat is an unknown quantity at this point
Default RE: Looking to Lift - Can I increase my tire size?!?
yea, thats what i ment.
Old Feb 3, 2007 | 02:19 AM
  #22
Goat's Avatar
If you dont mind doing a little fender trimming to put on larger tires and don't do a body or suspention lift you still would gain ground clearance. thanks Kyle.
Old Feb 3, 2007 | 10:28 AM
  #23
nofear17bmx's Avatar
nofear17bmx is an unknown quantity at this point
Yea I guess your right, but the suspension lift will drop those arms 2 inches lower which will give you 2 more inches under the diff since the whole front of the truck is now sitting higher. You see on the big 6-inch suspension lifts they give you all new arms that are wider so that you can gain the ground clearance with out putting new tires on. Yes, bigger tires does play a big role in gaining clearance but I have a hard time believing you if you said a suspension lift wont give you any clearance without bigger tires. I may be wrong, but I have installed lift kits on atvs more then a dozen times and you gain a lot of clearance with just adding a suspension lift. Yes, I know atvs are a lot different from blazers lol. If I am wrong about this please clear me up, this is just what I have learned and I am by no mean a mechanic so I am always open to people correcting me.
Old Feb 3, 2007 | 12:21 PM
  #24
Goat's Avatar
No your right. a suspention lift will give you more clearance under your truck and with independent front, your right, i will give you more clearance. I have a solid front axle so we're diffrent. The diffs will drag without bigger tires. The point i was trying to make is ground clearance is almost directly realted to the radius of your tires. Bigger tires= ground clearance. But your right about independant front ends. But i'm no mechanic either, just have my own experiance. Still learning.
Flip01002003
Performance & Brainstorming
Jan 24, 2013 02:08 PM
PaulO2288
Headers, Intake, & Exhaust
May 10, 2009 07:43 PM
VanHalen
Dec 16, 2008 09:46 PM
MindlessCorpse
Sep 28, 2007 07:32 PM
j1cs
Jan 26, 2007 09:34 AM
