Blazer front end on an 05 Jimmy?
Old Mar 14, 2019 | 08:52 AM
Timmins_Jimmy's Avatar
Timmins_Jimmy is on a distinguished road
Found this:
while doing research on it, But doesnt address the bumper... the issue in question
Old Mar 14, 2019 | 12:31 PM
eshaw's Avatar
I went from a 1998 front clip to the GMC clip and used the original bumper reinforce
ment behind the front cover. Stock second generation radiator support, GMC (Envoy HID in this case) lights, bumper cover, and grill. The bumper cover should match the grille used. So, if you're using the Blazer stuff use a S10 /Blazer cover with S10/Blazer grille setup and the matching lights. Does this help?
Old Mar 14, 2019 | 12:59 PM
Yes it helps,
I know the covers need to match the lights, Blazer bumper with Blazer grille/Blazer lights
Just wonder if both Bumpers bolt on the same, I know lights and grille are same for both Jimmy and Blazer
I didnt know Envoy did HID, I will look into it
Old Mar 14, 2019 | 01:07 PM
What did you have to Modify on the Envoy lights to fit the Jimmy?
Old Mar 14, 2019 | 05:32 PM
N. Jensen's Avatar
From 1998-2000, there was a Jimmy trim called the Envoy....had a fancy interior, neon spoiler rear light, and some had these neato mosquito headlights on them.
In 2002, GMC made the Envoy based off the larger Trailblazer frame. Kind of confusing, since the S10 Blazer had a trim called the Trailblazer for a few years, as well.
Old Mar 14, 2019 | 06:18 PM
And learning is half the power!
Old Mar 15, 2019 | 09:24 AM
eshaw's Avatar
The lights interchange with any Jimmy type front. The trick is finding them with good ballasts. Be forewarned that everything about them is expensive too. Just good lenses alone run about 250.00 if they're nice and clear. The ballasts are also pretty large and mount down on the bumper reinforcement also, not easy to get at. I also suggest that when a person runs them, if their vehicle didn't come with them that you have a harness that is relay controlled and that they pull their current straight from the battery. If you use a stock harness sometimes the initial firing can pull enough juice to fry wiring. It's kind of hit and miss but I don't suggest that a person just plug in the factory harness and call it good.
Old Mar 15, 2019 | 09:27 AM
eshaw's Avatar
Also, the HID lights came as an option on some Diamond Edition Jimmys.
Old Mar 15, 2019 | 01:11 PM
OK
I think I am going to go with the blazer front end.
the mounts are not expensive and the main reason for this was headlights and being able to see better at night...
I am using the best Halogens i can find.. i tried LED but they disperse too much in Jimmy Housing.
Just want a good Headlight.
I will search for blazer front ends and order HID blazer lights
Old Mar 15, 2019 | 06:20 PM
N. Jensen's Avatar
Might look into blazen_red's HID retrofit thread. That's the direction I'm headed.
JT7257
Feb 27, 2012 10:51 PM
Dano01
Dec 22, 2011 02:37 PM
9Blazer6
Jun 16, 2011 09:19 AM
9Blazer6
Jun 15, 2011 10:16 AM
tmurph01
Apr 13, 2010 02:27 PM
