Bolts for roof rack
Old Feb 24, 2017 | 01:50 PM
stuntz's Avatar
stuntz is on a distinguished road
Default Bolts for roof rack
Where to find the bolts for the roof rack i cant seem to find anythign anywhere. I took mine off 1 of the four sets was rusted and stripped ripped out of socket left a hexagon shape. I would like to replace not sure where you look any help is appreciated. Should i replace the other 3 they dont look to bad.
Thanks
Old Feb 24, 2017 | 02:46 PM
Brian Hinzpeter's Avatar
Brian Hinzpeter is on a distinguished road
take a known good bolt to the hardware store and get one matched up and while you are already there just replace all 4, bolts are cheap.
Old Feb 24, 2017 | 05:38 PM
stuntz's Avatar
Default Looks to be a special bolt or attachment built in
The removed rusted shows a hex but the ones existing are circle. it seems to be a special bolt. The ones that are remaining do not just come out so not sure. I would like to replace all. but need to make sure i can find something to replace it with see existing pictures
hopefully someone can clarify
Attached Thumbnails Bolts for roof rack-20170224_182952.jpg   Bolts for roof rack-20170224_183002.jpg   Bolts for roof rack-20170224_183235.jpg
Old Feb 24, 2017 | 06:30 PM
rexmburns's Avatar
Super Moderator
Use a bolt and put a big washer on the back side. I did this with all of mine when I built my roof rack and no issues at all. I don't think you are going to find that insert anywhere. Just don't forget to put some sort of sealant on there if you go with my method!
Old Feb 24, 2017 | 07:15 PM
chevyriders's Avatar
Those are called "nutcerts" the tool to put them in is called a threadsetter. Almost like a rivet gun with different sized mandrels. We have to order the nutcerts thru our local Autobody Supply company. Rex's nut and bolt idea is the right way to go unless you want to spend 100+ on the tool
Old Feb 25, 2017 | 08:43 AM
stuntz's Avatar
Default removing
Should i remove the other 6 or will i do more damage trying. these 2 came out because they were rusted. Should i just use bolt and washer on the the ones that are removed already and just replace the bolts on the others leaving the "Nutcerts" in place? i feel that are in there good any trick to removing them?
Old Feb 25, 2017 | 08:54 AM
If there's nothing wrong with the rest, I would just leave them alone. No need to make more work for yourself
Old Mar 7, 2017 | 01:31 AM
CaRParts102's Avatar
CaRParts102 is on a distinguished road
Thanks
If you haven't found anything to help you... I have a complete roofrack with bolts available on the Jimmy I am parting out
Attached Thumbnails Bolts for roof rack-16830521_10210423071785964_1844046103_n.jpg
CPLSeraphim
May 20, 2014 05:48 PM
RobRad
Mar 24, 2014 06:08 PM
davtak
Jan 10, 2007 04:33 PM
haloboy99
Apr 25, 2006 07:13 PM
timetoblaze
Nov 16, 2005 01:08 AM
