fog lights
Old 03-18-2009, 11:42 PM
jeffreys25's Avatar
jeffreys25 is an unknown quantity at this point
so all i need to do is connect the wire to a switched power source and it should work?
Old 03-18-2009, 11:51 PM
bandidolenny's Avatar
Post The mostly in english paper of confusing intructions
If you followed the instructions and If you have wired and grounded and fused everything correctly. Then yes, it's a possible maybe.
Old 03-19-2009, 04:57 AM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
ROFL... What he meant was; "In theory".
Old 03-19-2009, 10:51 AM
ZR2nut's Avatar
ZR2nut is an unknown quantity at this point
I don't know what year blazer you are working on but on my 99 BlaZeR2 ,I mounted the relay to the front of the under hood fuse box.There is a hot post on the outside of it for 12v.I put an inline fuse between the relay and the post. I only ran one wire to the interior.
This was for the switch. I wired mine into the factory headlight switch.This way I could leave the fog light switch in the ON position and they could automatically turn on/off with the headlights(NON DRLs on 99s)Otherwise for the fog lights to come on I have to manually turn on the parking/headlights.This way if I try to get out of the BlaZeR2 with the lights turned on,it will warn me. I have seen alot of my buddies wire up the fog lights to operate solo and they forget to turn them off and it's hello dead battery!
Old 03-19-2009, 11:47 AM
If you wire up the switch (to activate the relay) to a switched ignition source under the dash, you can never leave the lights on and they
SWANNERZ
08-13-2014 05:05 PM
Benedict1337
12-10-2010 08:30 AM
tmurph01
04-13-2010 02:27 PM
R2P
11-01-2009 08:03 PM
ewingmh
05-13-2007 07:21 AM
Quick Reply: fog lights
