How do the springs that keep the door open go in?
Old Mar 3, 2008 | 03:13 PM
98BlazerLT4x4's Avatar
98BlazerLT4x4 is an unknown quantity at this point
Default How do the springs that keep the door open go in?
I spent like 3 hrs trying to compress that sucker into the door? Any advice would be helpful.
Old Mar 3, 2008 | 06:08 PM
Blazin_Jason's Avatar
Default RE: How do the springs that keep the door open go in?
Get the proper tool, called a door spring removal tool. Or carefully put it into a vice compress it and use like a zip tie to hold it tight. Then put it back into the door, and remove the tie. I prefer using the tool, well worth the $15.
Old Mar 3, 2008 | 08:26 PM
A zip tie will not hold the spring. I broke bailing wire in the process of trying to hold the spring in the compressed state when I did my driver's door.
The proper spring compressor is only $20 from Eastwood.com (Light Truck Door Hinge Spring Tool). It was $16 when I bought mine before I tackled the passenger door.
Old Mar 4, 2008 | 12:08 AM
Thanks, I'm going to order the tool right now.
Old Mar 4, 2008 | 03:34 AM
thegr81's Avatar
Yea with the proper tool its a cinch to accomplish!!
Old Mar 4, 2008 | 08:00 AM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Justgot the one I ordered two weeks ago...I have to replace my hinge pin for a second time.
Old Mar 11, 2008 | 11:30 PM
1955chevyhams's Avatar
1955chevyhams is an unknown quantity at this point
Double thanks! Saves me the time of re-inventing the wheel like last time I did this!
Old Mar 11, 2008 | 11:36 PM
WolfPack's Avatar
Euro you're doing it a second time? Do you use your door an incredible amount? Or is it a lack of keeping it lubed? Or maybe even....A DEFECTIVE PIN?
Old Mar 12, 2008 | 12:00 AM
I will actually be helping a co-worker with this sometime soon on his 'new-to-him' 2000 Bravada.
MikeTastic
Aug 8, 2012 04:41 PM
tttlesabre
Lifting Tech
Jun 3, 2012 04:30 PM
chris015
Feb 14, 2012 10:20 AM
NYCJUDGE
Aug 28, 2011 04:35 PM
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
