Painting your dash?
Old Jan 22, 2006 | 01:29 PM
LittleDan911's Avatar
LittleDan911 is an unknown quantity at this point
Default RE: Painting your dash?
I Was Wondering If Anyone Has Painted The Whole Dash Everything (Up By The Window, Air Bag Cover, O-S&!# Bar) Cause I Was Also Thinking About Doing It Cause Its Cheap And Creative But Just Takes A Lil Bit Of Time..................
Old Jan 22, 2006 | 01:33 PM
85FSBSilverado's Avatar
85FSBSilverado is an unknown quantity at this point
It would be best to take out the dash, but the cheap way to go would be to tape over the windshield and cover everything else you don't want to get overspray on. I would cover the vehicle, doors, take out what is not meant to be painted, sand/clean it, spray on some etching primer, and paint it. Depending on the type of paint (several out there) you will probably want to clear coat it. Check the can for details.
Make sure you don't get a paint that would cause glare. It's bad at night when your interior lights are glaring off your dash (if they happen to be on) and you are unable to see because of the glare from the windshield.
Old Jan 22, 2006 | 02:12 PM
Another thing to note is that when painting over plastics and some of the ruberized dashes, you will need to have a paint with the proper flex addative. You don't want your new paint job to crack when you push on it.
Old Jan 22, 2006 | 02:27 PM
Yep. I'm not sure, but I've used DupliColor Wheel Paint on my horn with no problems. I don't use my horn frequently, though, and have had no problems. It is heavy rubber, and not the foam-type rubber. There are ways of removing or sanding them. If necessary I can look them up for you.
Old Jan 22, 2006 | 07:34 PM
Yeah I Was Thinking About Using The Paint Used On R/C Car Bodys (Lexan) WItch Has A Flex Addative In it....But Not Sure If It Work
Karcinagin
Tires and Wheels
Feb 15, 2013 09:18 PM
Brian_D
Apr 20, 2010 10:35 PM
hooah68
Sep 7, 2009 04:02 PM
thoffman79
Feb 18, 2009 12:02 AM
mysons95
The Chop Shop
Nov 5, 2008 06:37 PM
