Peeling clear coat
Old Oct 23, 2019 | 10:19 AM
sdkid's Avatar
sdkid is on a distinguished road
Default Peeling clear coat
Typical peeling. How will this look if I pressure wash the flaking off then just buff the body? Is the result worth the effort?
Old Oct 23, 2019 | 07:43 PM
I would take the hood off, sand it with a 2000 grit, clean and clear coat over. Same amount of effort as hoseing and buffing, I think... just do light coats to prevent dripping.
Old Oct 23, 2019 | 08:45 PM
I had peeling clear-coat under my rear side window. I removed the loose bits and sanded it down to ease the edge. After cleaning I applied new clear-coat from a small spray can. Where I did not have over-spray it looked great. To get rid of the over-spray I wet-sanded the areas starting with I think 600 grit and ending at 5,000 grit. This resulted in a surface so smooth that water would bead on it.
I'd do some research on sanding clear coat first to double check the grits I used.
Old Oct 29, 2019 | 12:32 PM
sdkid's Avatar
Pretty much scattered over the entire vehicle. Might try the spray job to the hood yet this winter and see how it turns out. Thanks for the advice.
Matt Evan Cinquini
May 28, 2019 12:17 PM
antman94
Feb 9, 2012 03:12 PM
AGirelli
Sep 5, 2009 11:59 PM
wdb4719
Detailing
14
Jan 1, 2008 08:05 PM
AtreyuManiac
Dec 16, 2007 11:02 PM
