Removing Stickers
Old Mar 30, 2010 | 09:17 AM
MuddBunny84's Avatar
Banned
yahh i've used goo-gone, wd40, lighter fluid, was even told gasoline works (haven't had the opportunity to try that out though), and Pb-blaster...industrial wd40 and a finger nail *after using my ice scraper in winter to pry off all the chevy&blazer emblems* lol which doesnt matter the scratches are soon going to be taken care of.. or one of those hot hands...i found work too...get it hot stick it on and alternate between a hot gun and heating pad and wd40 fingernail and shop rag.. its soooo easy lol almost any thing with ethanol or any thing that has a strong alchohol odor i've found works its even come down to using mouth wash...listerine...just takes a little longer...
Old Mar 30, 2010 | 09:36 AM
DKSDAD's Avatar
Heat gun and carb cleaner. But watch it they all are right the heat gun will get the metal hot and burn the paint so make sure not concentrate the heat too much on 1 spot.
Old Mar 30, 2010 | 10:32 PM
devilman414's Avatar
devilman414 is on a distinguished road
hello snap on makes a crug thug that uses a rubber cog whell to remove decal and glue cost 300-400 dollars. astro also makes one that uses a solid rubber wheel works well cost used to be around 130 dollars with 12 wheels .
both will also remove two sided tape that holds on body side mouldings then clean up with wax and grease remover thanks and good luck
Old Mar 31, 2010 | 05:34 PM
Chriscursle81's Avatar
Banned
Chriscursle81 is on a distinguished road
Yeh I just took off my roof rack but am concerned bout leakage when it rains, i screwed bolts back into their hioles but looks outta wack.. Any easy way to fix ? Maybe bondo and silicone??
deegan26
Dec 7, 2009 08:42 PM
Blazerx85
Detailing
57
Oct 20, 2009 12:08 AM
Scooterewski
Mar 23, 2008 09:24 AM
bitbandit
Detailing
Oct 26, 2007 10:32 PM
EuroGoldLS
Aug 20, 2007 09:44 AM
