Shift Boot
I am assuming you are talking about a floor shift model.
If so, remove the shift ****. There should be a small screw through the side of the **** that is loosened with an allen wrench. If I still had my Bravada, I would be able to snap some pictures.
thats a floor shift model..but there should be a small screw that holds the part where you place your hand(brain fart and cant think of its name) once you remove that screw that part should come off, then the boot itself should clip in where the boot meets the console and if you pull up on that youll be able to slide the boot off.
cwiththehad
Sep 5, 2007 01:14 PM
