Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
Improve differentials
Old Jan 20, 2009 | 06:37 PM
papacope's Avatar
Default RE: Improve differentials
if you do change your gear ratio in the rear, you will have to do the same to your front end. open diffs are a bitch.
Old Jan 29, 2009 | 10:27 AM
DdayK5's Avatar
DdayK5 is an unknown quantity at this point
Found out on Randy's Ring and Pinon web site that the 3.08 is on the carrier break side to go higher up to 4.10, am I under standing that correctly for an 8.5 inch?
Old Jan 29, 2009 | 10:30 AM
There is a different series carrier for the higher gear ratios (lower number). I believe the cut off was 3.42 for the proper carrier series to go to and past 4.10.
Old Jan 31, 2009 | 09:55 PM
DdayK5's Avatar
If I go about improving the differentials is the seal kits necessary as in am I removing any existing seals to install the upgraded ring and pinions. Swartlkk- Sounds like it would be best just to up grade the carriers anyway.
TheBeastofPC
Mar 27, 2011 07:14 PM
roamer
Mar 17, 2011 05:19 PM
MrRox
Mar 23, 2009 11:27 AM
red_dog007
May 7, 2008 04:51 PM
user 1016
May 4, 2006 10:59 PM
