Performance & Brainstorming Want to free up some HP? Looking at headers? Ask your performance related questions here!
trans cooler
Old Dec 6, 2011 | 06:54 PM
killallblue's Avatar
killallblue is on a distinguished road
Default trans cooler
what ones are u guys using how do like them
Old Dec 6, 2011 | 09:24 PM
AJBert's Avatar
I think I have a B&M cooler, been a few years since I installed it. Can't say I've really noticed it as I don't have a trans temp guage. But I haven't overheated my trans since installing it.
Though, I didn't overheat it before installing it.
Old Dec 6, 2011 | 09:45 PM
will check it out
Old Dec 6, 2011 | 10:36 PM
Rottidog's Avatar
X2 on the B&M Super Cooler. From what I've read & my experience there are none better. A word of advice - do not use the regular hose clamps they come with. 1 of mine let go & the trans pumped out 5 quarts or so of fluid at a stop light. Luckly there was a auto parts shop I frequent a few blocks away & I got some 1/2" fuel injector clamps to replace them.
Old Dec 7, 2011 | 01:05 AM
thanks guys how long did it take u guys
Old Dec 7, 2011 | 07:11 AM
Another vote for B&M Supercooler.
Here's a tech article on both the cooler install & a shift kit from a long time ago:
Trans Cooler & Shift Kit Install!
There are other threads discussing the inlet/outlet, mounting, etc.
Old Dec 8, 2011 | 09:38 AM
Rottidog's Avatar
Not too long - pulled the front clip off & removed the upper fan shroud so I could access both sides of the rad easier. Made sure which trans lines where which & hooked it all up.
From the trans to the rad then out to the B&M & from there back to the trans.
Routed the lines safely, zip tied in place & checked the trans fluid after letting it idle in gear so the torque converter was pumping.
dunontme
Dec 15, 2009 03:18 PM
Jetfixer
Jul 11, 2006 05:02 AM
ivannj
Jan 16, 2006 04:17 PM
quontush
Engine & Internal
Jan 14, 2006 10:48 PM
