1999 Blazer 2WD leaking differential oil from wheel
I replaced the brakes but have differential fluid leaking. Do I have to remove the wheel, rotor, caliper etc and can I get to the bearing and seal that way or do I have to go through the differential? Thanks,
Yes. The brakes have to be removed to slide the axle out. Make sure the instructional videos you're watching are for a GM 10-bolt differential. Also look at pictures of normal and excessive bearing wear patterns on the axle. If your axle shows too much wear, your new seal won't last.
latunguley
11-17-2014 09:15 PM
Drew4711
10-06-2012 12:47 PM
fslobodecki@yahoo.com
04-15-2011 03:29 PM
98BlazerLT4x4
03-04-2008 06:00 PM
