4wd w/ No Front Springs???
Old Dec 31, 2009 | 04:33 PM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
Severely warped front rotors will make the front end vibrate. But it will be more pronounced when the brakes are applied.
Old Feb 27, 2010 | 05:31 PM
upmaine's Avatar
upmaine is on a distinguished road
I have a 99 4wd blazer and I had the same problem with the front end shaking at speeds between 65 and 75 and I had my mechanic go thru the whole front end and he could not find anything wrong so all I was left with was changiing the tires. So I went out and purchased 4 new tires and that solved the probelm. The front end does not shake anymore at all.
Old Feb 27, 2010 | 05:39 PM
It's simply amazing what new tires will do for a vehicle.
I think the OP has the optional anti-gravity units on his vehicle that would explain why he doesn't have any springs under it.
Old Feb 27, 2010 | 07:18 PM
LunchBox's Avatar
LunchBox is an unknown quantity at this point
Originally Posted by swartlkk
This system works quite well actually.
Well...on the road, anyway...you gotta admit the t-bars are a joke for offroading.
I know, I know...not the point of the topic...
Back to the topic, there is a way to fix a shaking front end over 65-70mph, and it's free!
*DRIVE THE D@MN SPEED LIMIT!
Old Feb 27, 2010 | 07:27 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
Highway speed?
Originally Posted by Sisk
I still think it's a tire issue.
And where are you getting this info that "just about every 4wd Blazer has the same identical problem" which is this shake? I've NEVER had an issue with mine. I don't recall seeing make complaints here about it either, and there are a lot of 4wd Blazer owners here. I'm curious to see where you got this info from.
i agree with you on this sisk. i have 2 different tread/brand tires on the front than the back and i have the same vibration problem. its alot more pronounced with the 2 different sets than my summer tires (which are all 4 the same).
another thing that it could be (kinda doubtful). a guy i work with cannot take his blazer on the highway anymore because his vibration is so bad. his harmonic balancer is bad. i know not suspension related but something else the op could consider.
Old Feb 27, 2010 | 08:57 PM
kevin turner's Avatar
kevin turner is on a distinguished road
Yeah, that t bar is made out of spring steel. If you was to mark it in a spot ans jack up the lower control are you will see it move. Thats how you get the spring. But i have to say ive never heard of one without a coil, leaf or t-bar. My self i like the t-bar you can lower or rasie the frount with and its free. You can do a t-bar crank and shackles for around 25 bucks. You cant lift a coiled vechile or lower one for 25 bucks. Chevy has been doing this for years(you must be a ford man).
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
dsrp
Jan 12, 2010 03:48 AM
3hondacrx
Jul 22, 2009 11:46 PM
Big E
Suspension Tech
Feb 12, 2009 08:25 PM
lt170chevelle
Lifting Tech
Sep 25, 2008 04:19 PM
