Ball joints... Moog vs AC Delco?
Old Mar 4, 2015 | 01:23 PM
newguy's Avatar
I do the same a few times a year. Should clean the rust better but dont. Lazy I guess
Old Mar 4, 2015 | 09:15 PM
Bagherra's Avatar
Bagherra is on a distinguished road
About how long does it take to replace a ball joint?
I think I'm gonna tackle mine in a few weeks...also, any pointers?
I think mine are still factory...
TIA!
Old Mar 5, 2015 | 03:12 AM
newguy's Avatar
TIA!
should only take a few hours. If yours are factory they are riveted on, you will need a sharp chisal or a grinding wheel to get the of. Grinder makes quick work of it
Old Mar 5, 2015 | 08:24 AM
jkyle187's Avatar
jkyle187 is an unknown quantity at this point
A sharp cold chisel, a steel punch, 5 lb hammer and a wiz wheel..no grinding wheel. Cut an X in the top of rivet with wiz wheel then cold chisle the rivets tabs off then punch them out.
Old Mar 5, 2015 | 08:10 PM
Easiest and fastest way I found, is remove the knuckle completely to give you more room. Then grind the top of the rivet off flush, or even into the ball joint a bit. Then ***** punch the center of the rivet, and drill a 1/8" hole about 1/4" deep. Stick a drift, (not a punch) in the hole, couple whacks with a BFH and the rivet pops right out. The 1/8" hole provides a relief so the top of the rivet compresses rather than mushrooms when you whack on the drift. Use 5/16" grade 8 bolts with prevailing torque nuts, not the cheesy 1/4" ones that come with the new joint.
1fastls1ss
Dec 12, 2013 03:39 PM
GunsOfNavarone
Jun 5, 2010 10:47 PM
robjamber
Jan 1, 2009 07:55 AM
wienerdog
Nov 12, 2008 09:47 PM
Blazin_Jason
Suspension Tech
Feb 24, 2007 12:44 AM
