Ball joints... Moog vs AC Delco?
should only take a few hours. If yours are factory they are riveted on, you will need a sharp chisal or a grinding wheel to get the of. Grinder makes quick work of it
Easiest and fastest way I found, is remove the knuckle completely to give you more room. Then grind the top of the rivet off flush, or even into the ball joint a bit. Then ***** punch the center of the rivet, and drill a 1/8" hole about 1/4" deep. Stick a drift, (not a punch) in the hole, couple whacks with a BFH and the rivet pops right out. The 1/8" hole provides a relief so the top of the rivet compresses rather than mushrooms when you whack on the drift. Use 5/16" grade 8 bolts with prevailing torque nuts, not the cheesy 1/4" ones that come with the new joint.
1fastls1ss
Dec 12, 2013 03:39 PM
GunsOfNavarone
Jun 5, 2010 10:47 PM
