clunking on bumps
Old Nov 7, 2008 | 03:50 PM
daxsteel's Avatar
daxsteel is an unknown quantity at this point
Default clunking on bumps
[align=left]I have a loud clunking noise only when I go over bumps, coming from my front end driver side . It almost sounds like something is loose. I thought it was the idler arm and changed it, but still the noise persists. One thing which I think it might be is the inner diff axle bearing. The seal is leaking slightly, but not dripping oil, and the axle has a little play it it. I hope its not that because of the amount of labor involved jus to fix it and would like to know for sure. Does anyone have any ideas what could be making this noise? if it is the inner axle bearing? or could be something else?
thanks for the help.
98 blazer
4x4
100,000 miles
[/align]
Old Nov 7, 2008 | 05:26 PM
abadinalbany's Avatar
abadinalbany is an unknown quantity at this point
Default RE: clunking on bumps
blown shock/strut
Old Nov 7, 2008 | 06:02 PM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
ball joints!!!!!!!!!!
Old Nov 7, 2008 | 06:39 PM
daxsteel's Avatar
[align=left]Thanks for the help, I replaced the shocks 4 months ago. I will check the ball joints tonight and see if they are loose.
[/align]
Old Nov 7, 2008 | 08:52 PM
Dew2008's Avatar
Dew2008 is an unknown quantity at this point
CHECK THE CONTROL ARM BUSHINGS!!! I had the same issue on my driver side, I replaced shocks, ball joints, tie rod ends and then I looked up and seen the bad bushing. $8 fix and the noise is gone. Just a though man. Hope it helps!
Old Nov 8, 2008 | 03:07 AM
WolfPack's Avatar
x2 on the balljoints
Old Nov 8, 2008 | 10:14 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
One other thing to check is the shock bolts since you mentioned changing them. I get a clunk from a loose shock mount. I need to take it apart and put some locktite because it clunks on some bumps. Go back around on the front shocks and make sure they are tight. If not then it probably is the ball joints.
Old Nov 8, 2008 | 12:53 PM
ORIGINAL: portcqb
I had the same experience after changing out the shocks on my old Bravada. The bushing portions on the replacements were not as wide as the originals which required more tightening of the mounting bolt to squeeze things together.
Old Nov 8, 2008 | 12:56 PM
c0a8l0v6i8n9's Avatar
c0a8l0v6i8n9 is an unknown quantity at this point
Torsion bar mounts??
Old Nov 9, 2008 | 09:44 PM
wienerdog's Avatar
wienerdog is an unknown quantity at this point
How about hood hindge arraching bolts?
TSB # 01-08-63-001
dbleobarbie
Nov 15, 2013 11:39 AM
musclecar70sfan
Nov 7, 2010 08:48 PM
BrokenBlazr
Feb 26, 2009 08:16 PM
Nick Bain
Feb 25, 2009 03:58 PM
bobbyj42
May 13, 2008 12:45 AM
