Donor Interchangability
Old Mar 25, 2017 | 10:37 AM
VintageIron's Avatar
VintageIron is on a distinguished road
Default Donor Interchangability
Hello and thanks for taking time to read this. I have a 1948 IH Panel Truck that came to me with a 1988 S10/Blazer 4x4 front clip spliced to the original frame, and the rear axle swapped out too. Frame code reads KC1A, PS 8-19-88. the truck has no motor, no transmission and no 4x4 drive train.
My question is, can I use a later model donor S10/Blazer 4x4, my goal is to put a GEN IV 5.3L in the Panel Truck, mated to a 4L60E with transfer case, so again, will a GEN 2 differential, and 4x4 running gear plug and play in a 1988 front frame?
Thanks again for reading this post!
Dave
Old Mar 30, 2017 | 12:03 PM
chris015's Avatar
id say it should. you may have driveshaft length issues,and on the 5.3 you will need a h3 hummer oil pan,and depending on if you are running a/c you will need to knotch the frame where the ac compressor will be.
Old Mar 31, 2017 | 06:58 PM
Thank you, I appreciate your reply!
Old Apr 1, 2017 | 12:13 AM
I'd like to see photos of this creation
Old Apr 1, 2017 | 11:09 AM
So far...
Attached Thumbnails Donor Interchangability-kbingarage1.jpg   Donor Interchangability-kbingarage3.jpg   Donor Interchangability-frame1.jpg   Donor Interchangability-frame5.jpg
catbird7
Apr 15, 2011 09:37 AM
akira19
May 6, 2010 10:55 AM
jmeccia
Jan 20, 2010 06:20 AM
NC93BLAZERLT
Nov 23, 2009 09:12 AM
blazingsadle
Apr 10, 2006 05:50 PM
