A few cv axle replacement questions
Old Mar 8, 2014 | 03:38 PM
newguy's Avatar
Default A few cv axle replacement questions
1998 blazer 4dr 4wheel drive gonna replace drivers side cv shsaft. what do I have to disconnect? end link, hub removal and lower ball joint? I searched but no luck. Thanks. How much time to do it also?
Old Mar 8, 2014 | 04:50 PM
okiedoak20's Avatar
Remove wheel.hub nut. Brake stuff..upper balljoint
And tie rod at knuckle....support lower control arm with floor
Jack.....knuckle will pull away and pop the axle loose
From diff.. then remove from knuckle the remove from vehicle
First axle is about 2.5hrs.....oh check fluid leve after your done.
Old Mar 8, 2014 | 05:22 PM
newguy's Avatar
Guess I was off a bit LOL. Gonna be replacing the hub also so I`ll remove that before the balljoint
Old Mar 10, 2014 | 01:22 PM
newguy's Avatar
Thanks Oki, think I may have broke a record. Without power tools 1 hr 15 min.
Old Mar 11, 2014 | 06:45 PM
okiedoak20's Avatar
That is quick.....glad to be able to help....
Old Mar 11, 2014 | 06:53 PM
newguy's Avatar
usually the hard part, dismantling was easy. Everything came right off
Jesster
Apr 4, 2013 05:44 PM
Fast Rider
Jan 19, 2012 03:20 PM
USMaverick101
Sep 27, 2006 09:14 AM
BLAZINSATAN
May 19, 2006 01:46 PM
firechicken 383
May 1, 2006 08:26 PM
