front brakes wearing out in 5 months. HELP
Old Mar 2, 2011 | 11:11 AM
litterbug's Avatar
Default front brakes wearing out in 5 months. HELP
hello. so back in july i bought new duralast gold ceramic brakes. you know the ones with the lifetime warranty that were 60 bucks. just a couple months ago i started hearing this horrible grinding and i look at my calipers and they were gone!!! i took them in and got new ones for free and also got new rotors too since the old ones were dug into pretty bad. checking them recently they look like they are wearing decently as they should.
any ideas on why the pads went bad so fast? they guys at autozone had no idea either.
Old Mar 2, 2011 | 11:13 AM
Did you replace or resurface the rotors when you installed the pads the first time? Were the calipers floating properly? Did one pad wear different from the other?
Old Mar 2, 2011 | 11:22 AM
litterbug's Avatar
i didnt have the rotors re cut because they were perfectly flat. and the outside pads was worn more than the inside ones were
Old Mar 2, 2011 | 11:24 AM
Sounds like the sliders froze up not allowing the caliper to float which held the outer pad against the rotor all of the time.
Old Mar 2, 2011 | 11:27 AM
litterbug's Avatar
thank you. my dad said it might have been something like that. so i cleaned the calipers off when i did it last.
Old Mar 2, 2011 | 08:23 PM
KM346's Avatar
KM346 will become famous soon enough
Im willing to bet the rear shoes are way out of adjustment, causing accelerated wear of the front pads. Take off your drums and check the condition of everything. The self adjusters rust up then the rear shoes will do almost nothing for stopping.
Old Mar 2, 2011 | 09:25 PM
litterbug's Avatar
i did realize this and replaced my shoes the same time as the front. i saw when i had my car up on jackstands completely and the back wheels would spin even when i was on the brakes hard.
Old Mar 2, 2011 | 10:30 PM
s_sranchboy's Avatar
s_sranchboy is on a distinguished road
Also when you clean your calipers you also need to clean everywhere the pads will slide and your caliper slides. Then you need to put a thin layer of caliper grease on all contact points and slides. I always put some on the back of the pads where they touch the calipers too to cut down on any noise in the future. I have had trouble with the Lifetime pads you are talking about. They are notorious for wearing rotors more quickly than the others and making more noise. That's just because they use alot more metal in the shoe compound than the cheaper ones to make them last longer. There isn't anything wrong with them, just letting you know so you may keep an eye on your rotors and if anything were to look funny you would have an idea why
Old Mar 3, 2011 | 12:42 PM
litterbug's Avatar
i gave my brakes the works this time when i changed them. they should last now
Melrock83
Mar 16, 2012 03:40 AM
Vinman
Feb 23, 2011 12:25 PM
Recycler
Jan 24, 2011 05:00 PM
bl_zer
Sep 30, 2007 07:52 PM
frankjc
Suspension Tech
Jun 25, 2006 09:41 PM
