leaf springs
Old Jul 10, 2011 | 12:12 AM
jaked up's Avatar
jaked up is on a distinguished road
Default leaf springs
the rear leafs in my 98 blazer ls are all worn out and saging so im going to replace them and i would like to put in 4 leaf springs out of a s10 pickup as my blazer only has 3 leafs i belive the 4 leafs from the pickup will give me about a 1-2 inch lift as well as helping for towing and just being better than my stock leafs. does anyone know if i can put thos leafs from a s10 pickup into my blazer and bc they have 4 leafs instead of 3 will they left my blazer some?
Old Jul 10, 2011 | 02:37 PM
nismo_2005's Avatar
nismo_2005 is on a distinguished road
They should bolt right In but they should sit the same hight.
But if yours are flat and worn then any nice leafs should seam like a lift
Old Jul 10, 2011 | 03:56 PM
Mczuk's Avatar
Mczuk is on a distinguished road
Check the length of the springs. I wanted to do the same but ended up just buying new from Generalspringkc.com. Every site I checked listed the first gen 1700lb springs as 26 front to axle and 28 axle to back where as the blazer springs were 24.5 and 27? I can't remember the exact measurements but they were different.
Old Jul 11, 2011 | 08:48 AM
jaked up's Avatar
wouldnt haveing 4 leaf instead of 3 leaf (s10 pickup=4 leaf s10 blazer=3 leafs) give me a small lift about 1-2 inch bc there are more leafs?
Old Jul 11, 2011 | 03:02 PM
nismo_2005's Avatar
The s10 and blazers are spring under so the extra leaf should just make it stiffer the only way it would lift it is with more arch. I have also Seen some s10 pickups with 3 leaf packs so maybe you can get the 4 leaf pack from a blazer
Old Jul 12, 2011 | 12:40 AM
jaked up's Avatar
iv never seen a 4 leaf pack in a blazer i will look around tho lmc truck only sells the 4 leaf pack for the pickups but maybe there in the blazers as well ill look into it im going to call the junk yard tomorrow and see how much a set of leafs is going to cost me
Old Jul 12, 2011 | 03:02 PM
nismo_2005's Avatar
Have you thought about a basterd pack? Cheap. Not to hard to do and it will give you some lift http://www.cherokeeforum.com/f51/s10...ard-pack-1380/
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
2Tone
Mar 29, 2007 12:20 AM
alamantia
Suspension Tech
Nov 17, 2006 11:14 AM
tommyd
Suspension Tech
Aug 25, 2006 12:11 AM
4lowlife
Suspension Tech
Mar 8, 2006 03:53 PM
