Oil on undercarriage 98 blazer
Old Aug 10, 2012 | 11:17 AM
shaughnessykid's Avatar
shaughnessykid is on a distinguished road
Default Oil on undercarriage 98 blazer
Good Morning,
I am new to this forum. My daughter just bought a 98 blazer 4 x 4 and I noticed that there is what looks like fresh oil on the undercarriage above the rear differential. Would this be spraying from the rear pinion seal? It looks like it is on the bottom of the gas tank. Any help or thoughts would be appreciated. Also, if there were any leaks from the front and rear axle seals where would this show up? Thanks in advance.
Old Aug 13, 2012 | 03:59 PM
I have since checked further into this and find that it is the output seals from the front differential to the axle. The leak looks like it is coming from the flange that is bolted to the differential where the axle goes into the diff. Anyone know step by step what you have to do to replace these?
Old Aug 13, 2012 | 04:10 PM
warthogdriver's Avatar
when mine leaked i just unbolted it slightly used a screwdriver to open it up a little bit.
then i cleaned the surface and applied some rtv and tightened it back up.
might not be right but it worked for me.
jmorris42
Jun 19, 2011 07:45 AM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
ComputerNerdBD
Apr 8, 2010 10:11 PM
michigan_engineering
Apr 7, 2010 01:37 PM
todaresqSL2
Nov 10, 2008 01:47 PM
