posi doesnt work
Old Jun 26, 2008 | 09:38 PM
NVANZEE's Avatar
Default posi doesnt work
i looked up the RPO's and found out that i have posi. The bad thing is that it doesnt work. I think it is powered by vacuume correct me if im wrong but were does the line connect. im assuming that i have a bad line. if anyone could tell me what to do it would help alot out on the trails.
Old Jun 26, 2008 | 10:12 PM
TripleBlackBlazer's Avatar
Default RE: posi doesnt work
RPO code G80? It is not vacuum controlled. How did you test to see if it works? They lock up if they see an axle speed difference of 20mph through a weighted clutch type of mechanism. It is purely mechanical.
Old Jun 26, 2008 | 10:20 PM
NVANZEE's Avatar
yes it is G80 and i have been stuck a few times and the wheel with out traction is always the one spinning
Old Jun 27, 2008 | 06:06 AM
Could be busted. You'd need to open up the diff to determine if it is.
Have you owned the truck since new? Its also possible that someone swapped in a different rear end.
Old Jun 27, 2008 | 06:24 AM
NVANZEE's Avatar
no i have only had it for about 8 months
Old Jun 27, 2008 | 11:32 AM
WolfPack's Avatar
I'll take your G80. Being busted and all...free?
americancarguy.com
Sep 6, 2010 09:55 AM
chris015
May 27, 2009 11:10 AM
in4lo
Dec 7, 2008 08:55 PM
stevenf
May 24, 2008 07:49 PM
idg4ever
Jan 22, 2007 07:41 PM
