posi-trac???
Old Nov 5, 2010 | 03:56 PM
mov4x4's Avatar
mov4x4 is on a distinguished road
Question posi-trac???
Does anybody know if the blazer LT's came if the posi rear end?
Old Nov 5, 2010 | 04:56 PM
No posi. Only the G80 Gov-loc.
Old Nov 5, 2010 | 05:04 PM
mov4x4's Avatar
What's "Gov-Loc"?
I was just curious because I spun mine in the field and it left posi marks.
Last edited by swartlkk; Nov 5, 2010 at 08:33 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Nov 5, 2010 | 07:28 PM
81Z4ME's Avatar
81Z4ME is on a distinguished road
My 95 spins both tires and my 96 only spins one.
Never tore into them just assumed the 96 did not have a pos unit.
There's a lot of different names for how the rear end work. Some don't work exactly alike but may have the same effect. I've always called anything that spins both rear tires any time you hit the gas a "pos" rear end.
positraction, limited slip, darn, can't remember what Pontiac called theirs.
My 86 IROC has different unit that the 88 Formula but both spin both rear tires when the pedal goes down.
Old Nov 5, 2010 | 07:44 PM
mov4x4's Avatar
Ok how would be able to figure out if it has the G80 with out tearing the rear end apart
Old Nov 5, 2010 | 08:05 PM
69chevelle's Avatar
69chevelle is on a distinguished road
would be an rpo code 'g80' in your glove compartment...
assuming it was factory
Old Nov 5, 2010 | 08:08 PM
mov4x4's Avatar
Alright thanks
What if the only "G" code is "GU6" I think that's the gear ratio "3:42" would the axle housing have anything on it?
Last edited by swartlkk; Nov 5, 2010 at 09:01 PM. Reason: *Combining Consecutive Posts* - Please use the edit function to add additional information in your post if another member has yet to respond.
Old Nov 5, 2010 | 09:04 PM
If you do not have RPO G80, you do not have the gov-loc rear diff. That is unless someone installed one after the truck rolled off the factory assembly line.
The G80 is not a positraction unit in the traditional sense. If you want to learn more about it, more information is just a search away.
Old Nov 5, 2010 | 09:37 PM
mov4x4's Avatar
Ok so what diff would I have if the only RPO G code is GU6
Old Nov 6, 2010 | 09:12 AM
Um... Standard open...
Or as I said, someone could have changed it out. You really won't know until you pop the cover.
bigdaddykane93
14
May 8, 2014 08:54 AM
MB4x4
Aug 22, 2010 01:02 AM
fargoben67
Nov 16, 2009 09:47 PM
Nathan1991
Sep 16, 2009 02:35 PM
buckwheat
Jan 6, 2005 04:59 PM
