Rear-end mess!!!!!!
Rear-end mess!!!!!!
O.K.-bought a rear end for my 92 full-size blazer 4X4 off craigslist(BIG mistake!) and it is not what I was told it was! Did a # check and found out it is off a 96 to 98. Wont fit my truck. My rear end has 10" brakes the one I bought has 11". Can I buy the hardware(drums-shoes-ect.) and will it line-up with my springs and shocks?
The spring perches you can measure quite easily. So long as the rear came from under a 1/2 ton truck, it should line up properly.
Is it the same size axle or larger? Your '92 should have the GM Corp 10-bolt rear in it.
Why not keep the brakes?
Finally got a rear end that fits! Person said it was fine-no need to check fluid -should have! Doing 50 and it locked-up! Should I get another rear-end or re-build this one. How hard are they to re-build?
They aren't too bad to rebuild if you have the specialized tools to set the shims properly.
what tools would that be? could I rent them?
Google "rear axle rebuild" and have a read through a few articles.
intoodeep95
17
11-09-2012 08:53 AM
brino1
02-25-2011 08:05 PM
