rear gears in 4x4
Old Sep 20, 2004 | 06:37 PM
timetoblaze's Avatar
timetoblaze is an unknown quantity at this point
Default rear gears in 4x4
i was thinking about put 4.10's in the rear but im affraid i will destroy my transfer case if i go to put the 4x4 on during the winter with dif gears in front...and body replace the front and rear or anybody got any ideas?
Old Sep 21, 2004 | 05:02 PM
Dutch_EXP's Avatar
Dutch_EXP is an unknown quantity at this point
Default RE: rear gears in 4x4
You cenrtainly need equal gears front & rear if you go 4x4...
Why the urge of 4.11 gears? If you want rocket launches, consider replacing the stall converter with a higher rpm one...
Old Sep 22, 2004 | 02:05 AM
yeah but i still wouldnt have posi in the rear..
Old Sep 23, 2004 | 07:09 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
if you're goin to change the rear gear ratio, you MUST change the front. i take it you are getting a used rear posi unit? if thats the case, then you can unbolt the ring gear off it and put your original one back on.
Old Sep 25, 2004 | 01:11 PM
Dutch_EXP's Avatar
I have a 4x4 with posi (limited slip), but no 4.11 gears. (I have GT4 axle rear, 3,73 ratio (dup with 5 x 1) and G80 axel positraction, limited slip)
Maybe you should shop around for one of these, or better, find and G80 optioned rear axle with your current ratio.
James1965
Jan 16, 2012 11:32 AM
blazerbro84
Sep 24, 2010 06:57 PM
Always Broke
Sep 18, 2010 11:59 AM
97ssblazer
Feb 16, 2009 10:10 PM
Blazin_1t_up
Sep 11, 2008 10:51 PM
