rear shock install problem
Old Nov 14, 2008 | 05:40 PM
kevlar0991's Avatar
kevlar0991 is an unknown quantity at this point
Default rear shock install problem
bought new monroe reflex shocks for rear, i got the old one off, but cant seem to get the bottom of the new shock to slide on, it wont go on, i almost think i got the wrong shock, i took some pics, theres a metal ring in the center oif new shocks and rubber around that, the old one i took off has no metal ring in the center. did the ring part stay on the bolt or what. on the lower bolt it looks like a permanet ring there,
http://s429.photobucket.com/albums/qq12/kevlar0991/
Old Nov 14, 2008 | 11:39 PM
kevlar0991's Avatar
Default RE: rear shock install problem
solved, called a friend he saw the pics, and was sure that piece comes off, well he was right, i had a tough time getting it off, i used a shark edged punch and a hammer, and kept hammering at the slot at the top, then I finally got it loose enough to get it off, my 1999 blazer has 235,000 km on her, and the rear shocks had been on there for a long time, they where white in color for the rear they where so hard to get off, I found the front much easier but they werent white.. I also torched the bolt for a bit to help loosen it up, dont know if it helped.... ANyway rides a thousand times better with four new shocks, hope this post helps someone down the line....
Old Nov 14, 2008 | 11:40 PM
kevlar0991's Avatar
http://s429.photobucket.com/albums/q...t=IMG_2148.jpg
dimmuborgir6nik6
Nov 11, 2009 12:26 AM
ComputerNerdBD
Suspension Tech
Nov 1, 2009 02:23 PM
Ryanmatt135
Aug 15, 2009 07:09 PM
offskooring
Feb 15, 2009 06:09 PM
Schmev
Sep 21, 2007 01:43 PM
