Steering components 2001 ZR2 vs LS
Old Aug 4, 2018 | 05:30 PM
2004 Blazer's Avatar
2004 Blazer is on a distinguished road
Default Non-ZR2
Originally Posted by Vond88
I couldn't find any stickers in the glove box. I used the vin decoder and this is what I got.
Your a-arms and sway bar mounts are identical to a regular LS blazer. You have a ZR2 rear axle ( 8.5 instead of a 7.6 ) It should be a GU6 3:73 posi if original. Compare your rear leaf spring forward mounting point to a ZR2 that is different and hangs lower off of the frame to increase ride height.
Old Aug 4, 2018 | 06:13 PM
Rusty Nuts's Avatar
GU6 is 3:42 axle ratio. GT4 is 3:73 for the zr2.
Old Aug 4, 2018 | 06:21 PM
Oops ! I got it backwards. Thank you for correcting the information.
Old Aug 8, 2018 | 11:58 AM
Vond88's Avatar
Vond88 is on a distinguished road
I changed the cv axles and ended up with one that was different than the one that was on there. The one I got was shorter than the one already on it. Also the outer tie rods were different shorter again. It’s been a bit annoying, I’m not able to reach out to the original owner I’m the 3rd. I was ordering parts using my vin. Not even thinking that the parts on it were not oem. Do the parts I mentioned look different than they should be?
Old Aug 8, 2018 | 03:56 PM
We can't see the parts in question , however, If I were you I would replace everything up front with stock LS parts and don't pay too much attention to what you take off. The previous owner must have just pieced it together with whatever he had around at the time co mingling ZR2 and Ls components ( longer CV shaft,tie rod end, for instance ) That may also be the reason for the mismatched parts from side to side. I don't think you have a ZR2 rear axle since you did not mention spacers and it currently is not 2" wider than the front track width. It is probably a Ford Ranger or Explorer rear, who knows. Stick with it and you will get it back to where it needs to be and you will have confidence that it is correct and reliable again. Be on the lookout for more of this type of repair as you get familiar with it. Life is interesting and sometimes a challenge, but always worth the struggle. Good Luck.
Joshs4x4
May 13, 2012 10:36 PM
litterbug
Lifting Tech
Apr 8, 2011 10:47 PM
jdveron
Jun 14, 2010 06:18 AM
Logan
36
Dec 6, 2009 07:41 PM
99 Blazer 4x4
Oct 2, 2007 01:29 PM
