steering shaft play
Old Jan 21, 2012 | 03:23 PM
614blazer's Avatar
614blazer is on a distinguished road
Default steering shaft play
well my 98 blazer 4x4 had loose steering. i know i need an aglinment but while i was doing my lower intake and i took the air box out for more room i remeber when i had my truck jacked up in the front i can move my wheels side to side both wheels do. balljoints new wheel bearing also. auto shop said my tir rods and linkage is good. but the question is. is it normal when you grab the steering shaft it moves side to side about a quart of an inch and the steering wheel moves but my wheels dont. is my gear box need adjustment or need to replace the gear box completly. steering wheel moves sisde to side when i grab the steering shaft but steering gear box dosent and wheels dont move when i do this. drives fine just seems like steering is a little loose......
Old Jan 21, 2012 | 07:58 PM
ctyler's Avatar
ctyler is on a distinguished road
I adjusted mine tonight and it made a small but noticable difference.
One of the things I was looking at was the pitman arm and the steering shaft.
The wheels had a little play and the pitman arm would move and the shaft did not.
heres the wright up
Steering Box Adjustment - Some Tips
Old Jan 22, 2012 | 06:47 PM
jdog2pt0's Avatar
jdog2pt0 is on a distinguished road
Check tie rod ends, pitman arm and idler arm. I have a '98 Jimmy with play in the steering. Most of it is in the pitman arm as I replaced the idler and inner tie rod ends.
You can also adjust the steering box itself. On the top there will be an adjustment screw. You'll need a wrench and allen wrench. (I don't know the sizes) use the wrench to lose the bolt, then use the allen wrench to make the actual adjustments. VERY SMALL INCREMENTS (quarter turn or less at a time). If you tighten it too much, you'll give yourself hard steering.
Now, I do have one question though. What do you mean by grab the steering shaft and move it side to side? By side to side do you mean that it is physically shifting left and right?
Old Jan 23, 2012 | 04:48 PM
614blazer's Avatar
yea like ill grab the shaft and i can twist my hand side to side and my shaft will mover along with my steering wheel. but when i had it jacked up once i moved the wheels side to side at the 9oclock and 3 oclock and my whole steering shaft and steering wheel moved too. WTH. idk im lost shop saide everything is tight might be your gear box is going out. someone told me it could be the rag joint in the shaft wth. idk i just dont want to throw parts in it when that wasnt the problem. limited on $$$$$.
Old Jan 24, 2012 | 03:36 AM
jdog2pt0's Avatar
Any chance you'd be willing to post a video (doesn't have to be long) or some pictures demonstrating the play? It would help me get a better idea of what's going on.
Old Jan 24, 2012 | 10:04 AM
neo71665's Avatar
Worn rag joint
WOMKPorkchop
Dec 30, 2013 04:16 PM
blank
Sep 8, 2013 07:07 PM
meatchief
Apr 8, 2009 07:04 PM
duffy47
Mar 21, 2009 06:50 PM
newbie
May 31, 2007 10:45 AM
