Stuck Lower Ball Joint Removal
Got it out. That was ridiculous. Went through about 6 more drill bits. Even after the remaining piece of the ball joint was out, one of the rivets still wouldn't budge!
Had to drill all of them out from the bottom, which sucked; barely enough room for the drill under it. Once I found a decent 1/8" bit in the bulk pack I bought, it drilled through nicely.
For anyone in the future referencing this, load up on the 1/8", 3/16", and 1/4" bits. If you think 1 pack of 5-7 each will be enough, buy 3!
Best of luck
Did the driver side last night. Still had to drill the lower ball joint rivets, but only from the top, maybe 1/4" deep; just to get enough out of the control arm mounting holes. Three of them began rotating slightly as I was chiseling them, so I figured it would be an easier go than the passenger side. Took about 2.5hrs total to replace the ball joints and shock.
Hopefully no issue with the upper ball joint. I load them up with some grease prior to putting a load on them. The upper was leaking grease around the top flange. Hopefully once I get a load on it, it will seal so I can fully lube it.
ryanpraski
11-17-2010 08:13 AM
snowboarder6899
01-12-2008 04:58 PM
