Suspension leaning
Front chassis ride height is the vertical distance between the lower-most inboard point of the steering knuckle, nearest the ball joint, to the center of the lower control arm pivot bolt.
1996 & newer:
4WD (except ZR2) = 4.6” to 5.0” (4.8” is preferred)
ZR2 = 4.6” to 5.2” (4.9” is preferred)
Very easy to do: Measure from the knuckle straight down to the ground. Then measure from the center of the lower control arm bolt straight down to the ground. Then subtract the knuckle to ground measurement from the control arm bolt to ground measurement. The answer, (remainder) is front chassis ride height.
BubbaBrooks
11-16-2011 03:57 PM
