Tire Size limit??
Old Mar 8, 2011 | 12:41 PM
Eggs999Bacon's Avatar
Eggs999Bacon is on a distinguished road
Default Tire Size limit??
I have an 01' Chevy Blazer 2-door thats optional 4 wheel drive. I did nothing to the suspension at all. I realize that the wheel wells are rather small but I was wondering if anyone has a definite size tire that I can use that would be the biggest I can go without any wheel well problems.
I have tried to search on here but most people just went for the lift kit. I don't want to spend that kind of money (just dropped $1200 on a sound system but it was totally worth it with the crappy *** stock speakers that chevy dished out).
The tires would also be put on the stock rims. If you have any measurements that would be great. thanks.
Old Mar 8, 2011 | 12:45 PM
Benedict1337's Avatar
30x9.5x15 is the biggest you can go
Old Mar 8, 2011 | 12:46 PM
dimone545's Avatar
dimone545 is an unknown quantity at this point
there are a ton of articles on this bro.... If you dont mind some trimming you can fit 31's if I remember right...
Old Mar 9, 2011 | 05:47 PM
kyjonesy's Avatar
kyjonesy is on a distinguished road
i have a friend with a 98 2door he put 30x10.50x15 i believe and had some rubbing problems but was able to do some trimming and now only has a rubbing problem when the front end suspension is flexed fully. i have a 98 4-door in need of some bigger rubber. i've found several articles on google about tire size on stock suspension. maybe u should start there.
Old Mar 12, 2011 | 12:40 PM
Hanr3's Avatar
Look in the DIY section.
There is a thread about what fits and what hits.
Some options to get tires bigger than 30"
Old Mar 12, 2011 | 02:10 PM
89 Blazer Lebanon's Avatar
89 Blazer Lebanon is on a distinguished road
Default 31"x10.5 /15
Most Blazer can fit 31"x10.5/15 tires by cranking the torsion bars in the front and putting longer shackles in the back, but some of them get minor rubbing under severe flex, which requires minor trimming on the end (lower part) of the fender's arch (not the wheel well). Some only need the plastic trim on the fender arches to be removed (plastic ones are thick).
Old Mar 12, 2011 | 04:10 PM
Hanr3's Avatar
Cranking the torsion bars changes ride height, which strains all the suspension and steering parts. You also rub the bolts of the inner fender where it bolts to teh firewall. The more important difference, is you only gain 1/2" of ground clearance between 30" and 31" tires. Not worth the added wear and tear on the suspension.
I am in the process of rebuilding my front suspension right now.
I am replacing both the upper and lower ***** joints, bump stop, control arm bushings, and shocks on both sides. Plus I replaced the CV axle and hub assemble on the passengers side, and replacing the lower control arm bushings on the drivers side. Plus Im replacing the idler arm.
I have about $200 into parts and two weekends of work. CV axle covered under lifetime warrenty, and Autozone gives me a knock on my card everytime I spent $20 or more. The $100 hub assemble cost me $20. Used up $80 in credit.
Everything si original except the cv axle and hub assemble on the passengers side. My 2000 Blazer has 195,587 miles on the original ball joints. I run 30" tires since the day I got the truck in 2003 and it had 27,000 miles on her.
I figured it was about time to replace them. I'll bet you wont get 150,000 miles out of your ball joints with acranked suspension.
Old Mar 12, 2011 | 04:31 PM
I've only had to replace two of my ball joints since I cranked my tbars the whole way and that was over a year ago... now cv axles and hubs are a different story...
Old Mar 19, 2011 | 06:26 PM
davedidit's Avatar
davedidit is on a distinguished road
99 4 door
full t bar crank
1.5" schackle and a add a leaf
31x10.50 BF Goodrich Mud TA's KM2
the CV boots fail but the life time warranty ones from auto zone
not to hard to change takes 3 hours
Old Mar 20, 2011 | 07:50 PM
Brian_D's Avatar
Looking for a thread now on trimming..
wondering what and how much ill have to trim when i get my new wheels with the backspacing i want.
bigjohns96sport
Nov 26, 2009 09:57 PM
GMdesigner
Sep 22, 2007 12:16 AM
jagblazer01
Aug 9, 2007 01:08 PM
dieselfumes
Jul 28, 2005 01:01 AM
02 Vortech
Engine & Internal
Jul 12, 2005 03:27 PM
