Torsion bar question?
Old May 20, 2011 | 11:00 AM
Z3r0t0l0rEnCe's Avatar
Z3r0t0l0rEnCe is on a distinguished road
Default Torsion bar question?
Ok so I had to replace the drivers lower control arm due to the sway bar mounting welds failed. Yeah I could of rewelded it but for $20 at the junk yard I couldn't pass it up.
Anyways after I replaced it I noticed when adjusting the bolt on the torsion bar that I had to tighten it all the way and still noticed that the ride wasn't level. So I think that when I installed the lower control arm I may have indexed the torsion into the lower control arm wrong. Without redoing it all over again is there a easier way to fix this? Can I just put a longer bolt in place of the factory bolt to achieve proper ride height?
Let me know on your guys input.
Thanks
Johnny
Old May 24, 2011 | 02:05 AM
neo71665's Avatar
are you sure the t-bar is in right? There is a front and rear.
Old May 24, 2011 | 08:55 AM
To answer your question, no, you cannot just install a longer bolt. You really need to remove the bar and index it properly.
Old May 25, 2011 | 05:07 PM
So can I just loosen the one side, pull it back out of the lower control arm. Or should I just loosen the lower control arm and reindex it that way?
Old May 30, 2011 | 09:59 PM
chris99jimmy's Avatar
chris99jimmy is on a distinguished road
I am pretty sure you have to take out the control arm to reindex the torsion bar. I just replaced mine a few weeks ago for the exact same weld break. If I knew how to weld I would have just welded it to avoid all the trouble. Plus mine just started to pull to the left. I was waiting to do a front end alignment until after I add the lift schackles in back, but of course, those bolt are stuck. Anyway good luck.
azzr2
Mar 25, 2012 04:19 PM
mdehoogh
Suspension Tech
Dec 3, 2008 06:51 AM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
KenpoFish
Feb 5, 2008 08:38 AM
stevelknievel
Lifting Tech
Apr 23, 2007 12:57 PM
