Vacuum Switch Replace - How To
Old Jan 9, 2010 | 05:55 PM
vaportrail's Avatar
vaportrail is on a distinguished road
Default Vacuum Switch Replace - How To
Does anyone know if the only way to get to the vacuum switch on a 1997 LT (3 switch - 2HI, 4HI, 4LO) is to drop the front prop shaft?
I see no other path to get to it. I can't really even reach the vacuum lines to pull them off.
It about 10 degrees out and maybe I'm noy having a whole lot of patience in my attempts, but if I need to pull the prop shaft, I'd just as soon get on with that.
I have vacuum at the actuator all of the time and see no other routing that would connect it up.
I'm pretty confident that is has also destoryed the sleeve in teh front axle as it does not move at all, but I have to fix the vacuum problem first.
Old Jan 9, 2010 | 06:27 PM
jacobcnc's Avatar
jacobcnc is on a distinguished road
I just used a 7/8 wrench climbed underthere and it spun out. Nothing else is really in your way. You could take the drive shaft out if you want to get more room but not nessacary.
Old Jan 9, 2010 | 07:45 PM
vaportrail's Avatar
OK Thanks. Will give it a go tomorrow.
cjb2145
18
Oct 6, 2018 04:46 PM
cide
Nov 8, 2010 08:17 PM
blazin97
Oct 27, 2009 09:04 AM
IRO
May 26, 2008 07:16 PM
jameskline5012
Oct 23, 2007 10:07 AM
