Weird grinding noise when braking.
Old Jul 2, 2013 | 04:41 PM
rexmburns's Avatar
Super Moderator
Please make sure you report your findings to help others out in the future! Nothing worse than a thread that doesn't have a solution to the problem at the end
Old Jul 2, 2013 | 04:52 PM
Diaita's Avatar
Make sure the ABS sensors are properly installed also. I was working on a late 90s Chevy PU that had a heap of wasted parts thrown at it because the mechanic didn't install the sensor properly.
Old Jul 2, 2013 | 05:02 PM
Chevyblazerowner's Avatar
Chevyblazerowner is on a distinguished road
Oh I'll make sure to reply back
Heh, I know (well, I hope) I installed them correctly.
Old Jul 2, 2013 | 05:38 PM
So get this. It was the ABS. I unplugged the ABS cable from the front driver's side, took it for a test drive.
While the ABS light on my dash was on, the weird grinding stopped. It runs like brand new now, what with the new wheel wells and brake pads. No more constant noise from the wheel hubs, no more brake squealing, and no more weird grinding when I brake.
So the issue is indeed the ABS on the front driver's side. I'm going to keep it disconnected for now, and I'm going to replace the cable tomorrow and see if that fixes it.
Old Jul 3, 2013 | 02:49 PM
Problem fixed! I replaced the ABS cable on the front drivers side with the new cable that came with the wheel hub, and took it for a test drive.
On my first run around my neighbourhood, the brakes did the ABS-related grinding twice and the ABS light on the dash stayed on (because of me disabling the ABS yesterday). I double checked that the wires were fully plugged in and that they were clean, which they were, then took it out again.
It didn't grind a single time, and the ABS light turned off too! So if you have a weird grinding at the end of your braking, check your ABS cables.
I was going to replace the ABS cable on the front passenger side tire, but I figure if it ain't broke, don't fix it.
Old Jul 3, 2013 | 02:55 PM
rexmburns's Avatar
Super Moderator
Glad to hear all is well!!
Old Jul 4, 2013 | 02:23 AM
Thogert's Avatar
Thanks for the follow up!
luigi408
Oct 13, 2012 12:03 PM
KHS1907
Dec 22, 2010 05:51 PM
1911cdp
Jul 31, 2010 02:00 AM
97redls
Mar 12, 2009 03:14 PM
havrelm1
Feb 22, 2008 09:01 AM
