Suspension Tech Have a question about modifying your suspension? Ask it here.
1.5" shackles
Old Oct 19, 2008 | 10:38 PM
  #21
newbreed's Avatar
newbreed is an unknown quantity at this point
Default RE: 1.5" shackles
Not 100% on the body lift, Not a huge fan of them.
Old Oct 20, 2008 | 06:06 AM
  #22
mysons95's Avatar
mysons95 is an unknown quantity at this point
ORIGINAL: WolfPack
Yep...to get my 1.5' up front, I had to go 7 turns on the drivers side and 8 turns on the passenger. I suspect the weight of the brush guard affected the lift from each turn though..
When you say TURNS, do you mean 7 full 360* rotation of the bolt, or 7 swings of the wrench?
Old Oct 20, 2008 | 07:33 AM
  #23
WolfPack's Avatar
7 full rotations of the bolt. But it was over 2 or 3 different times of turning the bolt, jack down, drive around the block, measure, repeat.
Old Nov 11, 2008 | 08:22 AM
  #24
TimmiT's Avatar
TimmiT is an unknown quantity at this point
On the shackles, aren't you putting them in the same location, as far as the bolts go? Or are there different locations to bolt to the frame? I have been thinking about this, but have not looked under there.
Old Nov 11, 2008 | 09:12 AM
  #25
WolfPack's Avatar
Yea you are just installing a longer shackle in place of the stock shackle, to push the leaf spring and axle down farther from the body/frame to give you lift. The trick is to make sure you actually get the axle to drop down the 1.5' or 2', and not just absorb the lift by flattening out the spring.
Old Nov 12, 2008 | 08:40 AM
  #26
TimmiT's Avatar
I see what you mean, to a point. You are pushing it into shape with the jack, but how does it stay any differently when the jack is removed and the weight of the vehicle is pushing down, causing a reaction at the axle pushing up, and working to flatten the spring that is connected at the same locations either way?
Not doubting that there may be something to it, because I have not done it, but I cannot see it in my mind.
Your blazer in your sig looks awesome btw.
Old Nov 12, 2008 | 08:42 AM
  #27
TimmiT's Avatar
I guess what is to stop it from pushing back / flattening out like the right side of the pic you posted?
Old Nov 12, 2008 | 12:25 PM
  #28
WolfPack's Avatar
The spring rate of the leaf, and the force on the shackle bolt and mount keep everything in position. The shackle doesnt move, keeping the spring eye fixed. Then you pushed the axle down with the jack so that the spring eye meets the new shackle at the same angle as stock. Thats where the design of the leaf spring comes into play. The reason why the leaf can be flattened out is because if you do install improperly and you dont drop the axle down, just like how you can stand on the rear bumper and bounce, you can flatten the leaf during the install. Then the bad angle absorbs this flex, and keeps it in a flexed position.
What youre asking is the same for stock vs with shackles...The leaf spring is the suspension in the rear, so it supports the weight of the rear end, keeping its arch. The key is that the shackle angle remains the same.
Old Nov 14, 2008 | 10:32 PM
  #29
TimmiT's Avatar
Ahh, thanks. I believe I understand at this point. The Shackle does not move? It just acts as a vertical spacer?
I guess I have seen so many pictures of shackles installed like the right side of your picture that I thought that for the most part the shackle was there to provide additional flex down from the body, and sit the way the right side of your pic showed when there was weight on it.
jdespain
Lifting Tech
14
Jan 29, 2010 10:07 AM
dirtydave
Suspension Tech
Dec 18, 2009 04:21 PM
moose4553478
Lifting Tech
Oct 24, 2009 12:41 AM
Blindthieves
Suspension Tech
Mar 6, 2007 12:41 AM
jimmyboy
Tires and Wheels
Dec 4, 2006 09:46 PM
