Suspension Tech Have a question about modifying your suspension? Ask it here.
Front Single Axle Camber?
Old May 22, 2009 | 07:45 AM
oisinirish's Avatar
Findings.
Passenger wheel= 2.5 degrees out at the top
Driver wheel= 2 degrees out at top.
Anybody know if the adjustment shims are "stackable" napa shims go to 1.5 degree.
Shop manual says Camber should be +1.5 degree. So I' just try to get both sides the same.
Old May 22, 2009 | 10:22 AM
It looks like most manufacturers do not suggest stacking plates. You may have to do a combination of ball joint offset bushings and shim plates. Looks like the most you will be able to pull it back is 3* total... You may want to shoot for 0* camber even though the setting is 1.5* in.
Old May 22, 2009 | 10:32 AM
oisinirish's Avatar
Probably gonna start with the shims and got both to +1 degree and see how it rides. Rotate the two "good" ,ha ha..better, rear tires to the front for a little while and see how the wear is before I blow money on new tires.
Can you put some kind of marker on the tread to see how it wears faster than waiting for a wear pattern in the tread?
Old May 22, 2009 | 10:35 AM
I have used powdered line chalk on a concrete floor to show the contact pattern before. It may work in your case to tell you if the tire is proper.
Old Aug 18, 2009 | 06:08 PM
t.lyttle's Avatar
t.lyttle is on a distinguished road
i went in for an alignment they said i had positive camber on the front left and they told me 358 to fix and do the alignment....does this sound fishy?
chowell
Mar 6, 2021 09:47 PM
blajeans
Jan 9, 2013 12:58 PM
USMarine1108
Oct 18, 2009 09:47 PM
stevelknievel
Suspension Tech
Jun 23, 2009 05:05 PM
AK8BLANK
Suspension Tech
Mar 3, 2007 07:55 PM
