Front Single Axle Camber?
Findings.
Passenger wheel= 2.5 degrees out at the top
Driver wheel= 2 degrees out at top.
Anybody know if the adjustment shims are "stackable" napa shims go to 1.5 degree.
Shop manual says Camber should be +1.5 degree. So I' just try to get both sides the same.
It looks like most manufacturers do not suggest stacking plates. You may have to do a combination of ball joint offset bushings and shim plates. Looks like the most you will be able to pull it back is 3* total... You may want to shoot for 0* camber even though the setting is 1.5* in.
Probably gonna start with the shims and got both to +1 degree and see how it rides. Rotate the two "good" ,ha ha..better, rear tires to the front for a little while and see how the wear is before I blow money on new tires.
Can you put some kind of marker on the tread to see how it wears faster than waiting for a wear pattern in the tread?
chowell
Mar 6, 2021 09:47 PM
blajeans
Jan 9, 2013 12:58 PM
